Activity Forums Adobe After Effects Strange motion blur/transparency effect
  • Strange motion blur/transparency effect
    Posted by Andrea Digiorgio on June 12, 2015 at 10:53 am
    Hello everyone, yesterday i rendered a comp which has different animated characters inside. When i saw the export i noticed that some characters present a strange transparency effect, instead of the motion blur effect i had set initially. You can see an example in the attached image.
    I tried different solutions:
    -turn off motion blur in the character comp
    -turn it on for all the layers inside it
    -turn on “continuosly rasterize” on character comp. But nothing changed.
    Some infos:
    -Characters are animated with Duik
    -Character Comps are 2000x2800px Square Pixels 25fps
    -Main Comp is 1920×1080 Square Pixels 25fps
    Thanks to everyone
    Alejandro Contreras vega replied 7 years, 3 months ago 2 Members · 2 Replies
  • Andrea Digiorgio
    June 15, 2015 at 8:48 am
    I’ve already tried but it keep showing this bug. I cleaned it 4-5 times in 2 days but doesn’t work.
  • Alejandro Contreras vega
    June 19, 2019 at 4:54 pm
    Hi.
    I have the same problem. You fix it?
