Activity › Forums › Apple Final Cut Pro › Strange glitches playing MXF from Avid in FCPX
  • Strange glitches playing MXF from Avid in FCPX
    Posted by Marco Feil on May 29, 2017 at 8:37 am
    Hello wise editors ☺
    I couldn’t find anything similar on the web so I hope one of you has a clue what it could be…
    We’ve got a weird problem with some footage we receive from one of our clients. They send us consolidated Avid projects and AAF files. The footage is from a Sony PDW 700, so i guess some kind of MOV container, codec XDCAM HD422 and just rewrapped to MXF at import (I don’t really know Avid or this camera).
    The footage plays fine in Quicktime, Resolve, VLC and (for the most part) Premiere.
    FCPX shows strange glitches and stutters (see attached file). Rewrapping with EditReady helps but then the Timecode gets stripped (already filed a bug report with them). Timecode in the MXF files show correctly in FCPX, Premiere and Resolve but does start at 00:00:00:00 in MediaInfo and EditReady.
    At the moment we transcode everything to ProRes in Davinci Resolve. It’s just one extra step since I go through Resolve anyway to convert the AAF project to FCPXML but I’d like to use the original media.
    Soo.. Has anybody got an idea where this problem might originate?
    11410_mxf.mov.zip
    General
    Complete name : …/Avid MediaFiles/MXF/1/13359012V01.D524E158FF14E0V.mxf
    Format : MXF
    Commercial name : XDCAM HD422
    Format version : 1.2
    Format profile : OP-Atom
    Format settings : Closed / Complete
    File size : 356 MiB
    Duration : 59s 400ms
    Overall bit rate : 50.2 Mbps
    Package name : 13359012 / Clip0579.new.03 / Clip0579.PHYS
    Encoded date : 2017-04-25 09:20:37.000
    Writing library : AAFSDK (MacOS X) 1.1.0.0.60
    IsTruncated : Yes
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : 4:2:2@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Format settings, wrapping mode : Clip
    Codec ID : 4B464141000D4D4F-0401020201040300
    Bit rate mode : Constant
    Bit rate : 50.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.965
    Stream size : 354 MiB (100%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Other
    Type : Time code
    Format : MXF TC
    Time code of first frame : 00:00:00:00
    Time code settings : Source Package
    Time code, striped : Yes
    Noah Kadner replied 9 years, 4 months ago 3 Members · 5 Replies
