Activity › Forums › Apple Final Cut Pro Legacy › Strange events Importing video Clips to FCP
  • Strange events Importing video Clips to FCP
    Posted by Eric Holzapfel on August 29, 2008 at 8:00 pm
    Hello Forum,
    I have a question in regard to importing video from a video camera.
    I am using a Canon HV20. FCP 6.0.
    I use the log and capture method to bring video in.
    I use the camera as my input device.
    I have a clip that I would like to import, lets say it is around 60 seconds of video. I start the log/capture, and I pause the clip where I would like to have an in point, and add the in point.
    I start the clip and let it run to the spot where I would like to place the out point, and add the out point. OK. I do it for a few more clips on the same tape.
    Let’s say I have logged 4 clips, and will use the batch method to capture the clips. I am/was under the assumption that I will have 4 clips captured clips when I finish. Let’s say I named the first clip Clip1, and the second Clip2, etc.
    I start the batch capture process, and the tape rewinds to the first clip I selected, and begins the import. But… it does a funny thing
    It adds a clip Clip1-1, Clip1-2, and Clip1-3, etc to the bin. When the capture is all done, I might have a series of clips, like Clip2-1, etc.
    What is going on here? Is FCP detecting where I might have pressed the record/stop button in the camera? It is puzzling to say the least. I have not paid that much attention to how many times I press the button in the field. I used to add black space, by covering the lens between what I thought were scenes. When I do that, it will capture the black as a separate clip, which seems to say, FCP detects when the record button is pressed.
    Any clarification on this one?
    Thanks for a great forum,
    eric
    Adam Keyes replied 18 years, 1 month ago 2 Members · 1 Reply
  • Adam Keyes
    September 3, 2008 at 7:38 pm
    I’m not sure…
    But make sure that, in the log and capture window, you have correct settings for the “capture settings” tab, and the other tabs also.
    Second, get a deck. Using the camera for capturing is just not efficient and maybe it’s causing your woes.
    Hope it works out…
    Adam Keyes
    http://www.eventreels.com
