Activity Forums Adobe After Effects Strange Effect in After Effects – with simple keyframe motion
  • Strange Effect in After Effects – with simple keyframe motion
    Posted by Eric Holzapfel on May 4, 2009 at 4:28 pm
    Hello Creative Cow forum,
    I have been playing around with After Effects CS4 (a trial copy) on
    a Windows XP machine. I created a PSD image in photoshop that is
    853 px wide and 1706px high. My idea being to do a vertical pan
    on the image in After Effects. I created an AE comp that is DV 16:9
    widescreen. I set a position keyframe at the “bottom” of the image, at about 426,250 (or whatever the values are), and at the end of the pan, set a keyframe at the end of the comp (comp is 10 sec long) at the top of the image. So my pan goes from the bottom to the top.
    About half-way through the pan I would like to stop and hold a constant y position for a second or so, and then continue to pan up. I put two keyframes at the y postion that have the same value (370). The x position does not need to change. My problem is that as the pan comes to the first 370 keyframe and passes to the second 370 keyframe, the image jumps up and down a few pixels between these two keyframes.
    I did not try to render the comp, I am just previewing it. Is it me or Windows XP?
    Eric Holzapfel replied 17 years, 4 months ago 2 Members · 2 Replies
  • Todd Kopriva
    May 4, 2009 at 4:35 pm
    The spatial interpolation mode for your keyframes is Auto Bezier (the default). You can change the behavior that you’re seeing by setting the spatial interpolation mode for these keyframes to Linear.
    Some people call the motion that you’re seeing ‘boomerang’ motion.
    See “Spatial interpolation and the motion path” for more information, including links to some good videos here on the COW about this issue.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Eric Holzapfel
    May 4, 2009 at 10:13 pm
    Hello Guys,
    Once again Cow to the rescue! I have been watching the podcasts by your panel of experts (not using the term loosely), including Ahron, but have not made it to the “boomerang and bezier” as yet, but now I will!!! – for my quick and dirty I will try Dave’s hold keyframe suggestion.
    Again, thank for this great forum.
    Eric
