Activity Forums Adobe After Effects Strange CTI :(
  • Strange CTI :(
    Posted by Lukas Pennings on March 31, 2009 at 5:13 pm
    Hello,
    I’m using after effects for a while now (GREAT STUFF:p) but somthing strange has happened!
    when i drag the yellow under striped values nothing happens(as preview) so i can’t see what i’m doing!
    Also when i make a sipmle fade in (with keyframes) opacity 0-100% in 1 second for example. The fade in is there but when i drag the current time indicator nothing happens! only if i release my mouse button i can see the changes, but not the animation.
    You can imagine this is pretty frustrating.
    Note that the “always previewm this view” button is activated.
    Elpe Design
    Dave Johnson replied 17 years, 6 months ago 2 Members · 2 Replies
  • Dave Johnson
    March 31, 2009 at 5:48 pm
    I’ve forgotten what it’s called, but it sounds like you accidentally turned off one of the buttons in the comp viewer window … it’s something like “fast preview”.
  • Dave Johnson
    March 31, 2009 at 5:53 pm
    I knew I had the name wrong so I opened up AE and i was way off … it’s the “Live Update” button and it’s in the timeline window, not the comp window. Sorry.
