Strange corruption on EX3 footage in FCP – what is this?!
I’m having some strange problems with my EX3 footage in FCP (6.0.5).
I download with Sony XDCAM transfer software (via cable), and the clips look fine when I’m previewing them in there. I then open my FCP project and import the clips, and often there’s a fine line-based corruption on the image.
It seems to be when there’s more movement in the image, or around big differences of colour/contrast, which suggests that it could be a compression issue, no?
I’ve exported a quicktime, so you can see what I’m talking about.
The strange thing is however, that when I watch the clip in Quicktime I don’t see the corruption (or don’t think I see the corruption). When I import the clip back into FCP I then see it again.You can download the clip here (95mb): https://rcpt.yousendit.com/647489268/c59e8ef4f0544af528315c3584a460f9
You can see it around the lamppost in the first part of the clip, then around the edge of the guy’s black jacket – in fact a little bit all over) in the second part of the clip. (It’s supposed to be a crappy video.) As I’ve said, you may need to drag it into FCP to see it.
I get it on clips from both my SxS 8gb cards. One card I’ve tried in an EX1 user’s Macbook Pro (straight in the side slot) and he has seen the same thing when he’s viewed one of my clips in his FCP. He said that he thought it was down to the mp4 compression and the occasional problems the camera has with creating an image this way, compounded by the strange way FCP tries interprets that, or tries to play it, and doesn’t always succeed. Does this have any truth to it?
Here I’m shooting at HQ 720/25p, but I’ve seen it at HQ 1080 too. I’ve tried downloading the same clips with Log and Transfer within FCP, and I get the same issue.
Although this doesn’t seem to be visible outside of FCP, I’m now very wary of using my camera for pro work until I know what this is, which makes things a bit difficult for me.
Can anyone advise at all? I’d be happy to post any further information you may need.
Much appreciated in advance.
Jamie Kennerley
