Activity Forums Adobe After Effects Strange bug in importing video files
  • Strange bug in importing video files
    Posted by Nick Montgomery on July 23, 2012 at 1:52 am
    Has anybody seen this before?…
    Importing video clip as elements for compositing some vfx shots together. All clips have a number as a suffix (eg. “_01”, “_2”, etc.). When I import one file in particular and drop it into a comp, it’s length gets shortened, gets a couple of seconds cut off the end.
    When I delete it, rename the file with a different suffix (“_2” becomes “_3”) and go through the same steps, import and drop into same comp, it stays unaffected.
    A little annoying bug.
    Kevin Reiner replied 14 years, 2 months ago 3 Members · 3 Replies
  • Tero Ahlfors
    July 23, 2012 at 6:19 am
    How are you importing it? Is AE interpreting the frame rate correctly?
  • Nick Montgomery
    July 23, 2012 at 3:19 pm
    It’s an .mov only a few seconds long. Either way I bring it in it gets interpreted the same way.
  • Kevin Reiner
    July 23, 2012 at 6:10 pm
    Give more info on type of footage. What is the codec, frame rate, screen size, audio sampling etc. What type of camera shot it?
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
