Activity › Forums › Adobe Premiere Pro › Strange audio glitch on output – is this a bug?
Felix Von nida replied 8 years, 2 months ago 25 Members · 53 Replies
Chris Tompkins
January 15, 2015 at 2:41 pmDid you try;
export the audio only to a mixdown track and import that back in for final exporting.
Chris
Sai Kelly
January 15, 2015 at 3:55 pmHi Chris, thanks for your reply,
No not yet, I’m trying a new export now with a slight change to the track/clip i believed to be the offending article. I tried a smaller export just around that clip before i made the changes and it didn’t have the glitch. Ive been having all sorts of export glitches around transitions with this project, up ’til now mostly visual. Like a repeating fade on a clip which is new. The image fades up and then in an instant blacks out and fades up again. Only on export though not in the timeline. Weird. I just shortened the clip slightly and it went away.
The hardest issue is viewing it back on LCD tv where the brightness is strangely higher even with the levels on the tv all turned low. It’s particularly bad because there are dark scenes in the movie that i hid things in darkness on screen but deliberately shot dark so that they would not be visible, like the edges of a pool but on this tv, they are sooooo visible. Only on this TV.
But thats for another forum…
Chris Tompkins
January 15, 2015 at 4:15 pmYup, I’ve seen those visual anomalies as well. Highly annoying and makes you question the “Pro” part of the software.
As a work around with issues I have exported a hi-res Master file, not a .mp4 and then confirm the master is good and then take that master file and compress that for your deliverable.
Chris
Sai Kelly
January 15, 2015 at 4:54 pmLol glad im not alone here. If i try to export at ProRes most of these issues come up. Plus it was all shot on 5DMKII with one GoPro shot at the opening and the Film Festival wants me to set the target bitrate to 50 and the max to 100 which i think is insane when the 5DMKII only shoots at 25mb/s anyway. But this may be just my limited understanding of bitrates!
That’s exactly what i would love to learn to do, how do i do that?!
To be able to export a Hi-Res master file both audio and visual and then re-import it as one video track and one sound track? is that it?
Can you talk me through this please? i feel like this would solve so many issues! -
Chris Tompkins
January 15, 2015 at 5:22 pmSounds like you’re already doing it.
Prores
Avid’s DNX
MOV
Uncompressed
Even P2 format as a master.Chris
Sai Kelly
January 15, 2015 at 5:27 pmYeah but i can’t get a decent un-glitchy version of those.
can you talk me through settings possibly?
Chris Tompkins
January 15, 2015 at 5:35 pmI don’t think the settings will get around the glitches. This is the issue, the glitches, the fix needs to come from Adobe.
Chris
Quintus Lubbe
August 19, 2015 at 10:16 amHi, Joe
I’m not sure if you ever solved this problem but I was experiencing the exact same thing. Audio glitches during playback and a strange 1 frame pop on the beginning of the audio on export but not playback in Premiere. Audio glitches would also start just after playing through a cross fade.
I eventually discovered that this was happening as a result of the denoiser plugin which I had in the audio track mixer on one of my tracks. After removing the plugin the issue has totally disappeared. All exports fine and no more glitches on playback.
Michel Henein
October 21, 2015 at 9:33 pmThis bug is still present in Premier Pro 9.0 CC 2015. I had to replace all my Constant Power fades with exponential and the noise glitch was gone.
Jr Klett
November 7, 2015 at 6:30 pmHey Chris,
I’m having this issue all the time with Premiere Pro CC 2015. It stinks. How do I create a mixdown track in my project?
I want to try it but I’ve never created a mixdown track before.
jr
