Activity Forums Adobe Premiere Pro Strange audio glitch on output – is this a bug?
  • Strange audio glitch on output – is this a bug?
    Posted by Joe Chow on May 13, 2014 at 6:40 pm
    I had this problem a couple of months ago and posted something about on another forum, and I’m having the same problem again. Basically, it happens when I stack 2 or more audio dissolves/fades on audio tracks in the timeline. For instance on audio track 2 I’m doing a quick fade out on a piece of music, and around the same point in the timeline I’m doing a slow fade-in of another piece of music on track 3, as well as a quicker fade-in of sound effect ambience on track 4. I’m using “exponential fade” effects. Everything plays back fine in Premiere Pro. But once I export my finished sequence and play back that video, I get a scratchy/static-like noise for as long as the various audio dissolves overlap. Since this has happened to me before, and I sort of forgot about it until I experienced it again yesterday, I got rid of the audio dissolves on 2 of the tracks and did rubber-band key-framing on those tracks using the same timings that I did with the “exponential fades”, and upon export, the static noise went away. As a control test, I swapped out the 3 “exponential fades” with “constant power” dissolves (instead of key-framing) and the noise came back on export.
    I am using CC version 7.2.1. Would like to know if others have experienced the same problem.
    Felix Von nida replied 8 years, 2 months ago 25 Members · 53 Replies
  • 53 Replies
  • Steve Connor
    May 13, 2014 at 7:52 pm
    I’ve just found the same thing with a multi cam project I’ve been working on, had to replace all the audio dissolves with key frames to fix it. I’m on 7.22
    Steve Connor
    Mellowing slowly
  • Chris Tompkins
    May 13, 2014 at 9:13 pm
    I’ve run into this issue as well.
    Had to export the audio only to a mixdown track and import that back in for final exporting.
    Chris
  • Peter Garaway
    May 13, 2014 at 10:23 pm
    This should be fixed in 7.2.2. Please let me know if you encounter this issue after the update.
    Sorry for the inconvenience.
    Peter Garaway
    Adobe
    Premiere Pro
  • Steve Connor
    May 13, 2014 at 10:31 pm
    I’m on 7.22 and I’m getting the issue!
    Steve Connor
    Mellowing slowly
  • Peter Garaway
    May 13, 2014 at 10:57 pm
    Hi Steve,
    Does this only happen on Export? If so, does this happen if you do a direct export from Premiere Pro as well as sending to AME via Queue?
    Peter Garaway
    Adobe
    Premiere Pro
  • Steve Connor
    May 14, 2014 at 7:58 am
    I’m getting it on playback and export from a sequence with a multicam clip. It doesn’t happen on the clip itself but when I put dissolves in the multicam clip audio I get it in the sequence I am editing the clip into.
    Steve Connor
    Mellowing slowly
  • Peter Garaway
    May 14, 2014 at 6:08 pm
    Thanks for the update. Could you please send a screen shoot of your sequence and settings. Also include exact steps to reproduce the issue. Please also include system info and note any 3rd party hardware/software.
    I’ve been unsuccessful so far.
    Thanks in advance!
    Peter Garaway
    Adobe
    Premiere Pro
  • Steve Connor
    May 14, 2014 at 8:07 pm
    Thanks Peter, I’m away from my system until tomorrow but I will send them on my return
    Steve Connor
    Mellowing slowly
  • Joseph Hung
    September 14, 2014 at 10:47 pm
    It’s back in 8.0.1. Both in PPro and in export.
    work.tulpapictures.com
    Twitter/Vimeo/Facebook: @TulpaPictures
    Mac Pro 2.4GHz 12 Core Intel Xeon (5,1) 32GB RAM
    Macbook Pro 2.3 GHz Intel Core i7 (8,2) 4 GB RAM
    OSX 10.8.5
    Adobe CC
    FCS3
    Davinci Resolve
    AJA Kona LHi/Blackmagic
    MSI Twin Frozr GeForce GTX 680 4GB GPU
    EVGA GeForce GT 640 4GB GUI
    RocketRAID 4322 SAS
    ProAvio 8TB RAID5 SAS
    Own Cams: BMCC 2.5K EF, GH3, Hacked GH2, 5DMKII
  • Sai Kelly
    January 15, 2015 at 2:37 pm
    Did anyone get this sorted? im having it too right at the end of a 3 year project heading to the film festival and i dare not update from 7.2.1 in case it introduces other issues!
Page 1 of 6
