Activity › Forums › Adobe Premiere Pro › Strange Audio Dips
  • Strange Audio Dips
    Posted by Zach Finch on October 31, 2014 at 3:19 am
    Hi everyone,
    I’m experiencing some bad audio dialogue that was recorded via a lavaliere mic that had something wrong with it. The track has no background tone (drops to -50db or so during lapses in dialogue) but also peaks really high at times. I’m trying to compress it to level everything out but not having much luck (i’m pretty inexperienced with audio mixing and compression). I have link to the video i’m working on, and was hoping someone has worked on something similar and could steer me in the right direction.
    https://www.dropbox.com/s/9ujal9to4f66sb9/Colleen%20O%27Laughlin%20Fine%20Cut%202.mov?dl=0
    Thanks so much!
    Z
    Joe Barta iv replied 11 years, 11 months ago 2 Members · 1 Reply
  • Joe Barta iv
    October 31, 2014 at 2:32 pm
    Sounds like there is a Gate applied to the audio. If it is that way in the original footage, there is not much you can do. If it is not in the original then check all your plugins and filters.
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
