Activity Forums Apple Final Cut Pro Straight lines look like staircases, what can I do?
  • Straight lines look like staircases, what can I do?
    Posted by Robert Bracken on August 29, 2011 at 7:01 pm
    Hello,
    The problem I’m having is while I’m editing straight lines look like staircases, they’re too jagged. What can I do?
    I’m shooting on MiniDV tape, SP quality. I’m editing in SD (which looks horrible on my monitor. but looks ok when airing.)
    I capture Pro Res LT
    David Battistella replied 15 years ago 3 Members · 4 Replies
  • Jeremy Garchow
    August 29, 2011 at 8:04 pm
    That’s interlacing and it’s normal.
  • Robert Bracken
    August 29, 2011 at 9:25 pm
    Why does my standard def footage look good in camera but look horrible while I’m editing it?
  • Jeremy Garchow
    August 29, 2011 at 9:27 pm
    [Robert Bracken] “Why does my standard def footage look good in camera but look horrible while I’m editing it?”
    Set your viewer to 100% and you can mess with the “show both fields” option.
    Interlaced footage isn’t going to look that good on a progressive display that can’t display interlacing correctly.
    Jeremy
  • David Battistella
    August 31, 2011 at 7:38 am
    Aldo try to male sure in fcp x that your viwer window is set to Two fields. You can chiose that in The top tight corner of The viewer window.
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://vimeo.com/battistella
