Activity › Forums › Apple Final Cut Pro › Straight Lines
Straight Lines
Posted by Wayne Garton on February 4, 2012 at 9:19 amCan I draw straight lines (horizontal or vertical) in FCPX or should I do them in Photoshop and import them?
Cheers
Wayne
New ZealandWayne Garton replied 14 years, 7 months ago 3 Members · 8 Replies -
Simon Ubsdell
February 4, 2012 at 9:28 amYes, sort of. If you got to the Generators tab you will find the Shape Generator.
Add that to your timeline. In the Inspector/Generator tab, select the square shape, turn off the outline, and select the fill colour of your choice.
You now have a coloured square. The final step is to go into the Inspector/Video Tab and use the X/Y scale to get the line thickiness and length you want, set the position and change the rotation if desired.
Or you could use Motion to make a simpler template for yourself.
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com -
Nick Toth
February 4, 2012 at 11:23 amYou could use a background generator and crop and position to your requirements.
Simon Ubsdell
February 4, 2012 at 1:52 pmOr you could use the all-new generator I have just made:
Simon Ubsdell
Simon Ubsdell
February 5, 2012 at 10:01 pmNo problem. Always nice to be able to help someone on the other side of the world!
Simon Ubsdell
Wayne Garton
February 6, 2012 at 1:31 amEspecially since both nations “shake” a bit every so often ..
Cheers
Wayne
New Zealand
