Activity Forums Storage & Archiving Storage Solution + Workflow? (one-man-band video producer)
  • Storage Solution + Workflow? (one-man-band video producer)
    Posted by Paul King on December 11, 2019 at 10:39 pm
    The graveyard of external SSDs is piling up and I need to get a proper storage/archival/backup workflow in place ASAP.
    Right now I’m using SSD External HDs ranging in size from 500GB to 2TB on a per-project basis. You know the deal, there’s several SSDs floating around with files/projects spanning multiple drives.
    Currently have ~ 9TB of footage I need to get properly backed up. Projects are a mix of 4K and 1920.
    I’m a one-man-band so having multiple connections is not a necessity right now. Ideally looking for something that can sit on my desk that isn’t too noisy.
    I’m ALL ears…
    Computer Specs:
    PC
    Intel Core i7 (8th Gen) 8750H / 2.2 GHz
    RAM: 32GB
    Windows 10 Home, 64-bit
    NVIDIA GeForce GTX 1070
    Connections:
    2 x USB 3.1 Gen 1
    USB 3.1 Gen 2
    USB-C Gen 2
    Mini DisplayPort
    HDMI
    Internal Storage:
    256GB SSD Operating Drive (Software/Programs)
    Seagate FireCuda Gaming SSHD 1TB – 5400RPM (Immediate Projects and Project Files)
    Andrew Johnstone replied 6 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Andrew Johnstone
    February 9, 2020 at 5:57 pm
    Yes I am all ears too.
    I am in a similar situation with a SSD per project sitting on my desk, plus any number of old HD’s and drives (some are duplicated back ups of old rushes) clogging up cupboard space in the office.
    I’d like to work my way back through my entire archive and back stuff up on line, just keeping current projects on project drives.
    I am not sure that our current web connection is fast enough, but must be soon. I certainly want to avoid having to buy more and more external drives though.
    Andy Johnstone
    Wild Dog Limited
    film & multimedia production
    http://www.wilddogworld.com
  • Bob Zelin
    February 10, 2020 at 2:06 pm
    the cloud is not fast enough. Your 20Mb/sec upload speed is not fast enough. You will be spending money on more and more storage for the rest of your life – not until Apple or Google or Amazon buys the cable companies.
    Bob
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Paul King
    February 10, 2020 at 2:37 pm
    Hey Bob! Any recommendations for the original post? I know you’re well-versed in this area.
  • Bob Zelin
    February 10, 2020 at 11:00 pm
    there is no magic trick here. If the answer is “how can I have more and more storage, without spending any money” – there is no answer.
    You either buy a giant RAID array, or you buy a large Network Attached Storage system.
    Either way, you are going to spend thousands (not hundreds) for a solution like this –
    I don’t care if it’s from G-Tech, Lacie, Promise, OWC, QNAP, Synology or anyone else. You need
    a minimum of eight large SATA drives, and you need a RAID enclosure a NAS enclosure.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Paul King
    February 11, 2020 at 3:55 pm
    I’m a little confused here. Not looking for the magic answer or worried about the investment at the moment. I think we’re looking for practical solution suggestions.
    On the RAID front, do you have specific recommendations for the scenario outlined in the original post?
  • Bob Zelin
    February 11, 2020 at 4:11 pm
    you can get this –
    https://www.bhphotovideo.com/c/product/1480231-REG/g_technology_0g10386_g_speed_shuttle_xl_112tb.html
    that is a nice 112 TB G-Tech G-Speed Shuttle XL with 112 TB, that is just plug and play for
    thunderbolt 3.
    or you can purchase a NAS like a QNAP TVS-872XT, but this will require a more complex setup.
    Nothing will be easier than buying a dedicated large RAID array.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Andrew Johnstone
    February 15, 2020 at 10:33 am
    Thanks Bob,
    Good ‘tell it like it is info’.
    I am starting work on a feature doc (70 mins run time) and we will need to figure out a fix for storage fairly soon. For various reasons we now cut on FCPX (which i loathed to start with but now love), but one of the the NLE’s strengths is also an issue – library size. Even a small 5-7 min project for broadcast or corporate clients (in HD) yields and FCPX library of around 8-900GB, so my best guess is that a project that we will be shooting in 4k for will need massive storage. At the moment we use individual 1 or 2TB SSDs for working edit drives form small projects and then archive the finished libraries to disk without the converted media.
    We already need more capacity for the rushes as our existing system is full, but the edit raid will need to be pretty sizeable too. and that is just for one project.
    What we have tried to do in the past is to retire old drives and use them as deep storage for old projects and old rushes. The worry is that the connectivity ports (USB3 or Thuderbolt 2) on these old drives will become obsolete before too long. I have already had to pull out old HDs from firewire raids from 10 years ago and we use a StarTech slot in drivereader to access any material on those.
    But in a nutshell you’re right. the quest for storage seems to never end. The Gtechs look like a good solution though…
    Andy Johnstone
    Wild Dog Limited
