Activity › Forums › Apple Final Cut Pro Legacy › storage solution for a 4:4:4 project
Posted by Rick Kz on May 11, 2007 at 8:03 pmi am curious if anyone has a rock solid storage solution for a 8 core mac pro and a kona 3 for a 4:4:4 project
is the 4Gb apple fibre card working for you? or do you find the atto celerity a more stable solution?
have you found a drive solution that works best? huge? rorke?
thanks very much in advance
rArnie Schlissel replied 19 years, 4 months ago 6 Members · 5 Replies -
Gary Adcock
May 11, 2007 at 8:15 pm[rick kz] “is the 4Gb apple fibre card working for you? or do you find the atto celerity a more stable solution?”
I have had much less problems with the atto card, but then the Apple card is 1/4 the price.
I have had personal issues with both at times, I have had rock solid success only with fibre solutions. My personal choice at this time would be the GSpeed XL.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Walter Biscardi
May 11, 2007 at 9:11 pm[rick kz] ”
is the 4Gb apple fibre card working for you?”I’m deciding between a Ciprico and Facilis Storage solution right now. Both can perform 4:4:4 and I’m pretty sure they both recommend ATTO as the card of choice.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Chris Borjis
May 12, 2007 at 7:05 amI’ve got the ATTO pci-e coupled via 4gb fibre to the Ciprico 4210, my speed disk test indicates it can easily handle 4:4:4
when I was looking to buy an array last year I told my sales rep that 4:4:4 dual-link SDI capability was a must, he advised the above configuration (over a year ago)
Simon Blackledge
May 12, 2007 at 5:12 pmWe have an 8 disk SATA array with raid5 we get 400MBs to 90% full…
p
Arnie Schlissel
May 13, 2007 at 3:37 pmWhich controller card do you use for your RAID?
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog
