Activity › Forums › Apple Final Cut Pro Legacy › stopping video causes Playhead to jump back one frame
  • stopping video causes Playhead to jump back one frame
    Posted by Joseph Barnett on May 18, 2009 at 8:10 pm
    Hello,
    Project: Appleproress / Progressive / 1024 x 576 (transcoded from red)
    Im having a problem on my external PAL monitor and external LCD. When i stop playback my external monitors update and jump back one frame. Ive never had this problem before. I naturaly assumed that it was a fields/ progressive issue, but this is happening on a DV interlace project too. I hope you can help. Below ive listed details:
    Current project:
    Red media transcoded with clipfinder to: Apple proress 1024 x 576
    Sequence preset: Apple proress 1024 x 576, progressive
    External Playback preset: 8bit uncompressed 720×576 625Pal (this has always played back my 1K proress media correctly letterboxed in my external monitors).
    AV settings: mirror on desktop
    View – All frames
    Aja Kona 3 settings: Primary set to 625 Pal
    Any advice will be gratefully recieved, i am often reading through this site for advice, but i haven’t come across this one yet.
    Thanks in advice,
    Joe
    http://www.guiltybynature.com
    Joseph Barnett replied 17 years, 4 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    May 18, 2009 at 10:17 pm
    Two guesses.
    Could be that you are stopping on a field rather than a frame.
    In the ‘codec’ tab of your Kona control panel, change the option to full frame instead of single field.
    Also, make sure that your playback offset is set to 0 in the System Settings > Playback control preference located under the Final CUt Pro menu.
    Jeremy
  • Joseph Barnett
    May 19, 2009 at 7:37 am
    Hi Jeremy,
    Thanks for the response, very helpful. Im pretty sure the we are set to full frame but the second option is one stone I haven’t turned over yet. Just lost my suite to an external client and editor but will check at lunch and report back.
    Thanks again,
    Joe
