Activity › Forums › Adobe After Effects Expressions › stopping the loop out expression
  • stopping the loop out expression
    Posted by Bjoern Dunne on February 20, 2009 at 12:31 pm
    loop_out("cycle",0)
    Hello there,
    i am animating a walk cycle of a paper cut-out puppet using parenting, lots of rotation keyframes and the loop_out cycle expression.
    I was wondering, if there is an elegant way to let the puppet stop walking, maybe even slow down gradually?
    Or will i have to set up the animation differently?
    Thanks in advance.
    Björn
    Bjoern Dunne replied 17 years, 7 months ago 3 Members · 3 Replies
  • Kevin Camp
    February 20, 2009 at 8:00 pm
    if you wanted it to slow down to a stop, then precomping the animation and using time remapping (layer>time>enable time remapping) may be the way to go.
    then you’d just be adding/adjusting key frames and their interploation… it may be as easy as ‘easy ease’ on the end keyframe, or adjust the curve in the graph editor to suit.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Filip Vandueren
    February 21, 2009 at 12:19 am
    I often use this expression:
    t=time; // or t=effect("Slider Control")("Slider");
    if (numKeys) {
    last=key(numKeys).time
    tt = (t>=0) ? t%last : last-(-t%last);
    valueAtTime(tt);
    } else {
    value
    If you change the first line by pickwhipping “t=” to a slider (see the comment part of line 1)
    , you can keyframe that slider as if it was the time of a timeremapped precomp for that parameter + as a bonus it goes below zero which loopOut & timeremapping can’t do.
  • Bjoern Dunne
    February 23, 2009 at 9:59 am
    Thanks Guys,
    Filips expression works nicely for slowing down the keyframe animation (which is a huge help already), but i cant seem too keep the loop_out expression working.
    The Puppet starts jittering and doing weird stuff. I pasted the expression under my loop_out expression. Maybe i was thinking too simple =)
    Thanks for the help guys!
