Activity › Forums › Apple Final Cut Pro Legacy › Stop Motion Set up with FCP 5
  • Stop Motion Set up with FCP 5
    Posted by April Suen on January 25, 2008 at 10:58 pm
    Heya FCP experts!
    I am trying to set up FCP 5 for a stop motion animation project. Does anyone how to get a live feed from my video camera directly into FCP so I can just drag each frame and stick it into the timeline?
    Any help would be much appreciated,
    Aprillia
    Rennie Klymyk replied 18 years, 8 months ago 7 Members · 14 Replies
  • 14 Replies
  • Paul Escandon
    January 25, 2008 at 11:05 pm
    You can get a live feed by hooking up a DV camera up via firewire and opening up the log and capture window. You can do a quick capture now to grab video from your feed (it will be more than 1 frame but that shouldn’t be a problem). Make sure the device control preset is set to non controllable device or else the capturing might not work as it will be waiting for timecode.
    There might be other tools to grab single frames from firewire but since this is an FCP forum that’s the only way I know to do it from FCP.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media – JPCU
    MacPro Quad-core XEON
    8Gb ram, ATI Radeon X1900 XT, 2TB internal RAID
    2 20″ Dell UltraSharps + Matrox MXO & 23″ ACD
  • April Suen
    January 26, 2008 at 12:24 am
    Hey Paul,
    Thanks for the response. I tried it and it worked with the live feed. Is there an efficient way to set each logged clip to 1 second still frame so I can keep it consistent?
    April
  • Paul Escandon
    January 26, 2008 at 12:55 am
    There is no way that I know of to do this from within Final Cut using this method, unfortunately.
  • April Suen
    January 26, 2008 at 1:36 am
    Thanks for the tips. I basically captured as fast I could and then reduced the speed.
    Cheers!
  • David Bogie
    January 26, 2008 at 2:50 am
    Easiest way to shoot stop motion animation for editing on FCP is with a digital single lens reflex camera. Import the stil limages as an image sequence into Motion, set your number of frames per frame. Motion willsave it as a movie. QT Pro will also import a folder of properly numbered stills.
    Stop motion animation is more than100 years old, there is nothing that hasn’t been log perfected in the mediu,.
    bogiesan
  • Mark Raudonis
    January 26, 2008 at 5:12 am
    I agree with Mr. Bogie on this one.
    Use a digital SLR, then just import the still frames in a sequence.
    Another advantage to this approach over the “live camera to FCP”, is the resolution of your basic cheap digital camera is approx 5-10 times that of even HD! Therefore, you can reframe or do moves in post that would be impossible if you brought in the “live image” at even HD resolution.
    I’ve done a fair amount of “time lapse” photography using this workflow and the results are astounding, considering how cheap the cameras are compared to a true HD motion camera.
    Mark
  • Alan Lacey
    January 26, 2008 at 8:13 am
    Just don’t go buggering your Nikon DX2s shutter/mirror by taking thousands of frames! That’s one very expensive repair.
    Alan
  • Uli Plank
    January 26, 2008 at 9:13 am
    They should be good for hundreds of thousands. I’ve shot time-lapse on a relatively cheap Canon S45 amounting to about 160,000 frames by now – it’s still alive…
    For stop-motion animation there’s an excellent program called iStopMotion from http://www.boinx.com .
    Regards,
    Uli
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
  • Alan Lacey
    January 26, 2008 at 2:21 pm
    Wow Uli that’s testament to the camera’s construction, is it an SLR and do you let the mirror flip every time?
    Alan
  • Uli Plank
    January 26, 2008 at 6:05 pm
    No, this is no SLR, but it has a mechanical shutter. Some companies, like Nikon, are quoting lifetimes for their SLR’s mirror mechanics, and the numbers are pretty high.
    Anyway, a collegue in Berlin has done lots of commercial time-lapse with his Canon 20D and it’s still doing well.
    Regards,
    Uli
