Activity Forums Apple Final Cut Pro Legacy Stop Motion Direct in Final cut!
  • Stop Motion Direct in Final cut!
    Posted by Max Christensen on July 15, 2009 at 12:27 pm
    I remember once seening, if i’m not mistaken, a guy hooking his lowbudget sony mini dv-cam up to his computer trough firewire, and taking pictures direct as we sad and spoke, in the capture-window. Those formed a singular 1 frame’s on his timeline, -leading to a stop-motion sequence.
    I have tryed, and tryed to redo this action, without any luck!
    The camera is in filming mode, the contact is trough to the capture-window. But then what?!?!
    How do i photograph trough Final cut!?
    PLEASE ADVISE MY FAVORITE KNOW-IT-ALL!
    Barthelemy Glumineau replied 17 years, 1 month ago 4 Members · 6 Replies
  • Barthelemy Glumineau
    July 15, 2009 at 1:06 pm
    i don t know about doing it natively in FCP, but i will simply take pictures with a still caméra. Name them in a logical order ( 001, 002, 003 …. you camera probably do it already) and then in the user pref adjust my still import duration to 1 frame. So then just drag all pic into your time line and they will be all playing one after the other, displaying just 1 frame for each one. Then you can play with your fps if you desire.
    There is even a better way in motion i guess, where motion compile all those files into one big clip.
    there is also a couple of software just for that ex: istopmotion
    http://www.strangefamilia.com
  • Mark Suszko
    July 15, 2009 at 2:37 pm
    Or just get istopmotion, it rocks.
    July 15, 2009 at 7:43 pm
    i didn t try , but maybe toonnloop could be a good free solution ?
    https://toonloop.com/
  • Max Christensen
    July 16, 2009 at 4:37 pm
    It should somehow be possible, just to do it directly in FCP.
    Anyone?
  • Russell Lasson
    July 16, 2009 at 4:42 pm
    I don’t know of anyway to make FCP just capture one live frame through Log and Capture.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
    July 16, 2009 at 6:00 pm
    i bet if some guys took the time to develop specific tools that mean it s something lacking in FCP. If not every body will be doing it that way. Maybe some plugins exist …?
