Activity › Forums › Apple Final Cut Pro Legacy › stop motion animation
  • stop motion animation
    Posted by Doug Normington on November 28, 2005 at 1:57 am
    Hey!
    My daughter and I are trying to do some stop motion animation like claymation.
    We are using DV camera attached to FCP with firewire. I only want to capture one frame at a time firectly into FCP. I don’t want to use tape.
    I see how to set the device control to none. But I don’t see how to captrue just one frame at a time.
    Anybody?!?!?!?!?!?
    NORMCO
    Peter Mcauley replied 20 years, 10 months ago 5 Members · 4 Replies
  • Neil Ryan
    November 28, 2005 at 2:30 am
    you can shoot with a digital stills camera (potentially better reoslution than a DV camera)
    Digital stills are named and numbered as sequentially, such as DSC_0001, DSC_0002 etc.
    You can then open this sequence of stills in QuickTime (one step using Open Image Sequence)and export then as a movie at the frame rate, size and codec you so desire.
    You can even open the stills in PhotoShop or similar and grade/manipulate the images individually (to fix one dud frame, like paint out a fly) or as a batch (to increase their sharpness with Unsharpen filter)
    Ideal if you can record the stills direct to your computer. This allows you to view the sequence at any given time.
  • Andy Mees
    November 28, 2005 at 8:03 am
    sorry to say this is not a function of FCP
    there is a great application for just this purpose, however, and it is loads of fun (but not free)
    check out Boinkz iStopMotion at https://www.istopmotion.com/
    cheers
    Andy
  • Max Frank
    November 28, 2005 at 12:54 pm
  • Peter Mcauley
    November 28, 2005 at 2:05 pm
    I’ve used Frame Thief with great sucess. You can download a free 30 day demo
    http://www.framethief.com
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.4.3
    FCP 5.03
    QT 7.03
    Kona 2 v1.1.4 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
