Activity Forums Apple Final Cut Pro Legacy stop frame ghosting in fcp
  • stop frame ghosting in fcp
    Posted by Stewart Charles on March 16, 2009 at 2:53 pm
    Not sure if this is an fcp issue or an aftereffects’ issue?
    I’m making a stop from animation. I have used after effects to assemble all the images and scale them and position them, as I would like. I imported them as a movie sequence. I’ve exported this as apple pro ress 422.
    In fcp I have slowed it down to 25% some clips I will want at 100% some less.
    It appears to have a ghosting effect on it when slowed down. When going though the clip one frame at a time on any thing less than 100% speed it appears there is a cross dissolve going on. The only way I’ve been able to remove this by using optical flow but on a 13 second clip its taken 36 mins and then in fcp its taken 18mins.
    Am I doing something wrong?
    Thanks for any help or advice.
    http://www.thin-kingmedia.co.uk
    Dino replied 17 years, 6 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    March 16, 2009 at 3:18 pm
    When you do slo mo with FCP alone, you’re introducing frame blending. That’s what you are seeing. Only way around this is to use optical flow in Motion. Faster computer=faster renders too…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Dino
    March 16, 2009 at 3:56 pm
    Under Motion tab, Time Remap, turn off frame blending.
