Activity Forums Zaxwerks stop easing of animation motion
  • stop easing of animation motion
    Posted by Judita on February 29, 2008 at 4:55 pm
    I have an animation that is easing (slowing) at the end of it, a tumbling ring, and I’ve turned off everything I can find to make it stop… any suggestions?
    Jon Okerstrom replied 18 years, 6 months ago 2 Members · 8 Replies
  • 8 Replies
  • Jon Okerstrom
    March 1, 2008 at 1:33 am
    Judy,
    Which app are you using – Invigorator or ProAnimator?
    Jon
  • Judita
    March 3, 2008 at 4:55 pm
    Pro-animator, the stand-alone version not the AE plug-in.
  • Jon Okerstrom
    March 4, 2008 at 1:59 am
    Okay… now some more questions.
    Where is the easing happening? You can adjust the amount of ease by using advanced mode and the ‘ease amount’ slider in the timing section. Move the Ease Amount to zero.
    Jon
  • Judita
    March 5, 2008 at 7:21 pm
    It’s a tumbling ring. The ease happens at the end of the motion.
    I’m not seeing an ‘easing’ menu anywhere. Will keep looking.
  • Jon Okerstrom
    March 11, 2008 at 12:41 am
    Hi Judy,
    Did you find it? The ease controls are visible when you select a transition segment, not when you choose the ending pose.
    Jon
  • Judita
    March 11, 2008 at 3:50 pm
    Hi Jon! I found it and indeed have all the ease settings on 0, yet it is still easing.
    I wondered if I could send you the project to look at.
  • Jon Okerstrom
    March 12, 2008 at 4:06 am
    Sure.
    jokerstrom1 (at) mac.com
  • Jon Okerstrom
    March 18, 2008 at 1:28 am
    Judy,
    Having seen your file now, I think the problem is that the second pose is not the same as the ending state of the first pose, to which an action has been applied. To solve the problem, I used the first pose to do the rotation then turned off animation in the following transition. That keeps the halo from trying to go back to its first position. I’ve sent you the file.
    Does this help?
    Jon
