Activity › Forums › Adobe After Effects › Stoke Effect to Reveal Scaling Issues
  • Stoke Effect to Reveal Scaling Issues
    Posted by Rituamajik on November 15, 2007 at 8:23 pm
    I’m trying to use the stroke effect to draw on Illustrator line objects, and as soon as I turn the continuous rasterize on, the lines get screwy when I try to scale them up. Any help?
    This also happens with the write on tool.
    Brian.
    Steve Roberts replied 18 years, 10 months ago 2 Members · 1 Reply
  • Steve Roberts
    November 15, 2007 at 9:06 pm
    I just tried copying a path in Illustrator, then pasting it onto a solid, then applying stroke, then enlarging the solid up to 2000% with Continuous Rasterize (CR) on. It seemed to work – the stroke is clean. It’s a little soft on the edges, but nowhere near as craptastic as it would be if you turned off CR.
    If I recall, Adobe added some useful scaling-upness from v7 onward. Give it a go …
