Stmp setting for a live record
I’m just double-checking, I’m doing a multi-cam shoot with Pan SDX-900 in 24pa mode. We are sending TC from one camera to the other cameras and to audio record (pro tools rig) Pro tools should be set to sync at 29.97. Since that is what is actually being recorded to tape.
I also plan to edit in true 24p timeline, end delivery is a 24p DVD. Once I remove the pulldown on capture is there any procedure for doing something with the audio? or will to sync fine from being to end.
– Cross posted in SDX forum
