Activity › Forums › Adobe Premiere Pro › Stills jump after Transition
  • Stills jump after Transition
    Posted by Dorian Weber on May 3, 2018 at 4:47 am
    Hello,
    I have to make a slideshow from Still Photos in Premier.
    Most of the transitions go smooth, but in some the image jumps.
    I made a search which said to set the Sequence to No Fields, which I did, but no change.
    Mostly I see the jump in a transition: Split and also Center Split (right at the beginning and the end of the transition). I removed all other effects with Keyframes to make sure those are not the cause.
    I really like that transition and would like to keep it in. I am using Premier 2015 Release 2.
    Any suggestions how I can solve that problem?
    Many thanks in Advance
    Dorian
    Dorian Weber replied 8 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
