Activity › Forums › Panasonic Cameras › still records to tape?
  • still records to tape?
    Posted by Matthew Mcnulty on May 8, 2007 at 4:13 pm
    Using the hvx200 and the firestore 100… cheap client wants only dv ntsc… whatever… check cleared we’re good… does the camera still record a signal to tape regardless of what format the firestore and camera are set to? curious to know if i will have a low grad back-up like i did with the old fspro4 and the old dv500 camera… honestly have not use tape since getting the camera…
    i know the minidv tape will only regard sd dv signal that’s cool
    Bbalser replied 19 years, 4 months ago 2 Members · 1 Reply
  • Bbalser
    May 8, 2007 at 6:23 pm
    The HVX200 will only record to tape in regular DV mode, not in HD mode. Set it for regular NTSC-DV, set the FS-100 to regular NTSC-DV, record to both tape and the FS at the same time. Simple as that.
    You can’t do tape in any HD mode on the HVX.
    – Apple Certified Trainer
    – Tutorials at http://www.bbalser.com
    – South Louisiana FCP Users Group
    – NOVAC Digital Filmmakers Institute
    – Event DV magazine
