still photos out of focus on timeline
Wayne Waag replied 11 years, 5 months ago 4 Members · 25 Replies
Greg Barringer
April 18, 2015 at 1:58 amWatch this video of DSLR images, even at internet quality the photos are sharp. On Blu Ray, they equal print quality.
Try these Project Properties:
Template HD 1080-60i (1920×1080), 29.970fps
Full resolution rendering quality: = BestThen render, let us know how your going to display it. Internet, DVD, BD, etc. and we can help with rendering
For the video above I used:
Main concept AVC/AAC (*mp4,*avc)
Internet HD 1080p
Customize Template
Variable bit rate
Check Two-pass
Maximum 24,000,000
Average 20,000,000
Encode mode: Render using CPU onlySome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jonathan Lyle
April 18, 2015 at 11:47 amThanks for the tips.
I will try putting out to DVD at 1080.
I will let you know.I may have to rescan the slides ata higher resolution. 2200 dpi? -
Greg Barringer
April 18, 2015 at 1:25 pmIt’s been a few years since a burned a DVD, I use Blu Ray. Maybe someone here can give a set of rendering settings for high quality DVD.
Wayne Waag
April 18, 2015 at 3:32 pmDVD does not support 1080. Regardless, my suggestion is to first do your project in 1080. The project settings suggested by Brian are fine, although my preference is to set the frame rate at 60P rather than 60i. Rather than burning to a disc, consider using a media player to deliver your production. Many newer TV’s already have that capability built-in. If you need to or want to make a DVD simply using the appropriate render template within Vegas. Be aware that the quality of your production will take a big hit. I wouldn’t recommend this option.
By the way, what slide scanner are you using? My suggestion here is to scan at max resolution. Hopefully, your scanner has some way of automatic dust and scratch removal. Since this is probably a family archive, do it in the best way possible. I re-scanned my family collection (12000+) some years ago using a Nikon LS-5000 at 4000 dpi. It’s a very tedious and time-consuming process. With 1400 slides, having it done at $.25 per slide may be a bargain. Good luck.
wwaag
