Activity Forums Apple Final Cut Pro Legacy Still photo problems in FCP sequence
  • Still photo problems in FCP sequence
    Posted by Mark Ring on June 9, 2007 at 8:18 pm
    Hello everybody.
    I am having a problem with using a scanned microfiche photograph in my video project. The photo was scanned from library microfiche as a tiff file. I am using FCP 4.5 and my sequence settings are 23.98 fps 16×9 anamorphic. When I open up the image in the FCP viewer window, the image looks fine. When I drop it into the timeline it looks fine as well -until I play it and it becomes blurry. There is a render bar over it, but when I render it , IT LOOKS HORRIBLE! Very coarse and grainy – looks like a bad dot-matrix printer. Does anybody know what I can do about this? It is the most important photo in the project, so I’d really like to use it. I have no other problems with other j-pegs, tiffs, scanned photos, etc. Any suggestions???
    Mark Ring replied 19 years, 2 months ago 4 Members · 5 Replies
  • Ben Insler
    June 9, 2007 at 9:34 pm
    How big is the photo? You might need to drop its resolution so Final Cut doesn’t have do the scaling and pixel interpolation calculations on a large scale. Final Cut’s not very good at that. Use Photoshop to scal the image down to the largest resolution you’ll need, and then bring it into FCP
  • Rafael Amador
    June 10, 2007 at 2:10 am
    You are not editing in a DV time-line? are you? If so, choose a better codec.
    rafael
  • Thaxter Clavemarlton
    June 10, 2007 at 11:09 pm
    Are you viewing for QUALITY on an external VIDEO monitor?
    You can only judge the quality that way… and not on the computer screen.
  • Mark Ring
    June 12, 2007 at 7:29 pm
    What timeline would you suggest?
  • Mark Ring
    June 13, 2007 at 8:28 am
    I meant which codec would you suggest?
