Still No Solution For OFFLINE RES PLAYBACK???
I’ve been working with the offline RT resolution. My sequence is set for blackmagic 8bit NTSC 29.97 playback. What I get in my monitor is a verticly strethced image. Top and bottom stretch but side to side stay at the original 320 resolution. Offline res is 320 x 240 photo jpeg. I’m currently working on a clients system with the Kona 3. I’m having no problem with my settings, the image is stretched into the screen on all sides. I REALLY WANT TO KNOW IF ANY OTHER DECKLINK USERS ARE HAVING THIS PROBLEM???
On my home system I’ve worked around the problem by using an old sony firewire converter, to get my video feed. But I’d really like to know why my decklink isn’t doing the job.
G5 dual 1.8
Huge RaidDecklink Extreme
