Activity › Forums › Adobe Premiere Pro › still no keyboard shortcuts for scale/position keyframes in Premiere Pro CC???
  • still no keyboard shortcuts for scale/position keyframes in Premiere Pro CC???
    Posted by Nick Natteau on August 10, 2013 at 1:46 pm
    I love working with Premiere Pro CC, but I was so hoping by now that we would finally have assignable keyboard shortcuts for adding position and scale keyframes. I don’t understand this because animation on stills is so often done in films and documentaries. So you would think that a keyboard shortcut would now be available to speed up the process if you’re animating a lot of stills.
    Is there any known possible keyboard shortcut work around for this, some type of plug-in perhaps?
    Or is mousing over still the only way to add keyframes in PPCC?
    Erik Mickelson replied 13 years, 1 month ago 4 Members · 4 Replies
  • Ann Bens
    August 10, 2013 at 2:09 pm
    I would go for AE.
    There is this nice new plugin for the Ken Burns effect.
    https://stumaschwitz.com/store/prolostburns
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Nick Natteau
    August 11, 2013 at 4:49 am
    Thanks very much for pointing this out, Ann. Will definitely look into it.
  • Paul King
    August 11, 2013 at 11:55 am
    Not sure these are so relevant with the way Premiere effects operate.
    When motion is selected, you can direct manipulate both position and scale. Both are visible when you twirl down motion and these are not really as useful directly in the sequence as they are in AE’s comps.
  • Erik Mickelson
    August 12, 2013 at 4:30 pm
    Try Boris Pan n Zoom
    https://www.borisfx.com/videos/BCCFxPlug/Pan-Zoom.php
    I have used it on projects in the past. Seems to work fine. Remember to leave your original image at 100%.
