Activity › Forums › Apple Final Cut Pro Legacy › Still need help, PLEASE!!!
Posted by Göran Thorén on September 10, 2005 at 5:00 pmI can
Rick Sebeck replied 21 years ago 3 Members · 3 Replies -
Jerry Hofmann
September 10, 2005 at 5:50 pmThis sure sounds like the BM card is causing some uglies… might reinstall it’s drivers, and also search/post this in the BlackMagic forum. I don’t have a whit of problems with a Kona 2 doing much the same… this is all BM’s 8bit codec used in capture and export, right?
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Göran Thorén
September 10, 2005 at 6:11 pmActually I capture and output everything in BM 10 bits. Since I
Rick Sebeck
September 12, 2005 at 8:20 pmHave you tried changing the sequence setting field dominance to “none”. If I have it set to “lower” my text is always pixelated. The green goo is because of drop shadows. Remove your drop shadows, and then you can render true YUV 10bit.
