Activity › Forums › Maxon Cinema 4D › Still Liquid & Glass Material (Beer Bottle)
  • Still Liquid & Glass Material (Beer Bottle)
    Posted by Jay Ingles on April 12, 2012 at 3:57 am
    I realize this subject has been covered many times, but despite hours of research and trials i am looking to you guys to help me out.
    I need to create a material that resembles the attached Corona beer bottle image. Most importantly the glass reacts as expected at various angles, and the liquid/beer is the same tone (but doesn’t require bubbles).
    I know lighting glass/liquids is tricky but have too many variables and am hoping someone can help.
    Thanks in advance.
    C4D R13 Project File: 3969_bottle1.zip
    Jay Ingles replied 14 years, 5 months ago 2 Members · 2 Replies
  • Brian Jones
    April 13, 2012 at 3:17 am
    – your bottle is single layered because the lathe won’t join the splines together automatically, glass needs to have thickness to look right
    – the beer can not occupy the exact same physical space as the glass, that’s a 3D thing – 2 transparent objects can’t have their faces in the exact same place or there will be artifacts in rendering – the trick usually is to make the beer a bit bigger or a bit smaller than the glass, the transparent objects either have a bit of space between them (which can look wrong too but not always) or the liquid actually intersects the glass which can’t happen unreal life but it usually looks ok if it’s small and it avoids the ‘face in the same place’ problem.
    – your scale is crazy big the bottle is 3000+ cm tall that’s not a real problem (though you can get too big) but it’s usually better to make things more of a ‘real world’ size.
    here’s a quick test where I joined the two splines, then lathed that, then made it editable, selected polygons on the inside of the bottle to it has the right shape, Split those from the bottle, closed the top (to make it ‘solid’ beer – which gives beer in the exact shape of the bottle, then made the beer slightly larger with a Normal Move which pokes the beer into the glass but the look is ok
    3973_bottle2.c4d.zip
    That’s the simple way there may be better ways
  • Jay Ingles
    April 13, 2012 at 12:07 pm
    Thanks Brian, this was extremely helpful.
    I was aware of needing to enlarge the liquid surface having watched this tutorial on cineversity, but definitely didn’t realize my lathe nurb was not behaving correctly.
    Really appreciate that you took the time to review. I’ll take a look at the file this afternoon.
    Thanks again
