Activity Forums Apple Final Cut Pro Legacy Still Images not rendering
  • Still Images not rendering
    Posted by Berenger Capmany on December 14, 2007 at 2:43 pm
    Hello,
    I just want to know if someone is facing the same problem.
    Macpro quad 2.66
    Decklink HD extreme
    FCS2 upto date
    working at 1080i50 in ProRes
    the problem is some still images are not apearing on the renders.
    Everything it’s ok in previews, when you scrub on the timeline, manipulate, etc…
    but whe you do a “render all” and “master to tape” some images.. just disappear.
    If you do a “render all” and then export a Quicktime Movie with current settings
    the resulting movie has also the same problem..
    any ideas?
    Berenger Capmany replied 18 years, 9 months ago 2 Members · 2 Replies
  • Matthew Grimes
    December 14, 2007 at 4:35 pm
    this happened to me the other day as well.
    If you have your image above a video track then lower the opacity of the video track or cut it out
    often times for b roll i just stick some images over my main video track, that is, until my pictures wouldn’t render ect…
    see if it works for you.
    the other thing that worked was lowering the resolution of the image in photoshop.
  • Berenger Capmany
    December 17, 2007 at 12:06 pm
    Finally!.. I’m not alone in this world suffering this “old-time-like” weird behaviors!
    I will go this afternoon to the Production Company.. and check all the situations where it happens. (Is not my own FCP, I’m hired there as a freelance editor)
    It happens to you in ProRes also? or have U find the same problem working with other codecs?
    thanks!
