Activity › Forums › Apple Final Cut Pro Legacy › Still Images In FCP Interlaced
Posted by Joseph Wilkins on May 29, 2008 at 2:24 pmI have a sequence in Studio 2 with the following settings:
720×480
DV/DVCPRO – NTSC
NTSC – CCIR 601
LOWER (EVEN)My video footage looks very nice, but when I import a JPEG into the sequence, it looks all jaggy like it is being interlaced. It’s very off-putting.
Can someone please help me solve this issue?
Thanks very much!
David Roth weiss replied 18 years, 3 months ago 5 Members · 6 Replies -
Rafael Amador
May 29, 2008 at 3:32 pmChange your sequence codec to DV50 or 8b Unc. In a DV sequence you can hardly make look good nothing. The DV compression is killing your JPGs.
There are few thousands of posts in this forum explaining how to improve the look of the movie, graphics or still when working with DV. Make a search. Loads of interesting information.
cheers,Mac OX 10.5.2-FC 6.02-QT 7.4.1
G5 2x2Gh 4GbRAM-BlackMagic Extreme
PMBP 17″Core2Duo 4GbRAM-AJA ioHD
JVC DTV-17″
SONY EX-1 . SONY PD170
..and always a big mess on top of the table. -
Kevin Monahan
May 29, 2008 at 4:01 pmIf your system cannot playback 8 bit, you may need to live with DV Compression. However, since 99% of all of those new to FCP do not use an external monitor, my guess is that you may not be either. You need to look into the external video monitor to see your real quality, the Canvas does not do that. It will fool you as it’s fooled many, many people. You can put the Canvas at 100% and get a reasonable facsimile of your graphics, however. Try that and see if they look acceptable.
Another thing, you should never use JPEG formats for video graphics. The only time you should use a JPEG is if it is the format of the original file.
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Joseph Wilkins
May 30, 2008 at 6:09 pmbut it’s not going to be on a whole number while it’s moving… that’s where the jittering happens
Jeremy Garchow
May 30, 2008 at 6:27 pm[joseph Wilkins] “but it’s not going to be on a whole number while it’s moving… that’s where the jittering happens”
AS long as your start and end keyframes begin and end on a whole number, you should have no problems with the interpolation in between.
David Roth weiss
May 30, 2008 at 6:50 pm[joseph Wilkins] “but it’s not going to be on a whole number while it’s moving… that’s where the jittering happens”
Joseph,
Check out the mini-tutorial at the link below. I think it will solve your problem.
David
https://www.drwfilms.com/Flicker%20Filter%20vs%20Directional%20Blur/Site%20Folder/untitled.html
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
