Still Image Question, Final Cut (express)
Hey all,
Like other posters, I have scoured the web (and other forums) for answers to this question before posting. And like others, the more I read the more lost and confused I get. Here goes.
I am editing a video using Final Cut Express 4.0.1. The video itself was shot on an iPhone 4, and so it is HD. (FCE tells me that the frame size is 960 x 540 – the video was imported from the iphone onto my mac using image capture; this resulted in h.264 files which I then converted to AIC so I could use them in Final Cut Express without rendering). This video will be perfect to display on a widescreen television when I am finished editing.
But here’s my problem. Throughout the video, I would like to include still photos that have a different (more square) aspect ratio. When I export a sequence that has both video and these stills, the stills are taking up the area of the screen that the video should be taking up, and the 16:9 video portions are squished from the top and bottom.
Is there any way to tell FCE: “Lock the frame size for this sequence at 960 x 540, and if there is a still shot that is outside of these dimensions, only show the portion of that still that falls within the 960 x 540 frame and do not squish the picture?”
I appreciate any help anyone could give me, and thank you for your time.
Best,
Matt
