Activity Forums Apple Final Cut Pro Legacy still image pause
  • still image pause
    Posted by Pia Morales on December 10, 2010 at 4:04 pm
    For some reason these two still images are giving me a hard time. After the fade from one to the other there seems to be a slight pause before the motion continues. Why is this?
    I’ve tried turning on and off the Frame Blending, making the images move in the same (and opposite) direction and I can’t figure out why the transition isn’t as smooth as it could be. Does it have something to do with the anchor points? I’m thinking therein lies the problem but still no dice.
    If I can get some help it would be much appreciated.
    Martha
    also both the pics are jpegs, if that makes a difference
    Pia Morales replied 15 years, 9 months ago 3 Members · 5 Replies
  • Tom Wolsky
    December 10, 2010 at 4:35 pm
    Are you looking at the rendered output? What format is your sequence? What is the frame resolution of the images?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Pia Morales
    December 10, 2010 at 4:52 pm
    I have rendered it and even exported a qt. sequence is 16:9, my first still is 640×396 and the second is 3264×1840. could that be it?
  • Tom Wolsky
    December 10, 2010 at 5:51 pm
    The first image looks too small and the second image looks too big. What format are you working in?
    All the best,
    Tom
  • Cali Cuello
    December 12, 2010 at 4:08 pm
    I recently had the exact thing happen to me, so instead of using the Fade in fade out transition, i used the pen tool, and after that there was no sorta freeze
  • Pia Morales
    December 13, 2010 at 3:01 pm
    Thanks Cali. I’m actually trying to use a cross dissolve so how would I go about doing this?
