Activity Forums Adobe Premiere Pro Still Image optimum resolution 1080i
  • Still Image optimum resolution 1080i
    Posted by Frank Butler on October 24, 2008 at 12:23 pm
    Apologies in advance if this is is an old question. I’ve had a search but haven’t found exactly what I’m after.
    I’m shooting my first project in 16:9, 1080i hdv, using Premiere Pro CS3 for the edit. I need to ask for some still images to drop in and have been asked to specify exactly what size & resolution of image I need. The images are all (I think) currently A4 portrait size that I can re-size in photoshop, but just need to know what I should be asking for in a way that will make it sound like I know what I’m talking about.
    I hope this makes sense. Many thanks for your help.
    Frank Butler replied 17 years, 11 months ago 4 Members · 4 Replies
  • Jeff Brown
    October 24, 2008 at 1:39 pm
    First, (and I know I harp on this a lot): Ignore DPI. Tell the print people to ignore DPI. It’s meaningless for video. You need to be concerned with actual _pixel_ dimensions.
    That being said, consider how much leeway you need for zooming or panning on the stills, and specify a size that will give you 1920 pixels wide at the maximum push-in. So, if you want to zoom in 200%, start with an image that is 3840 pixels wide (and at least 2160 high). You have a bit of leeway; probably a bit more if you use AfterEffects or other compositing program to do the moves. I’ve found 10%-15% enlargement is OK. Beyond that, the image gets noticeably soft. Your mileage may vary…
    This is all with square pixels, BTW. Much easier to deal with.
    hope it helps,
    Jeff
  • Mike Velte
    October 24, 2008 at 2:19 pm
    [Jeff Brown] “First, (and I know I harp on this a lot): Ignore DPI”
    Amen!…and the web also. I read many knowledgeable folks who mention DPI for video and web. There are no inches on a TV or monitor.
  • Jeff Pulera
    October 24, 2008 at 3:53 pm
    Ditto on DPI, but as far as the still image, if you do NOT plan on doing zoom/pans on the stills, just make them 1920×1080 with square pixels.
    HDV cheats by using a 1.333 pixel aspect ratio to get down to 1440 x 1080 and still offer 1920 x 1080 playback because 1440 x 1.333 = 1920, but for stills just use the full 1920 x 1080 and Premiere will interpret correctly in an HDV project.
    This goes the same for Adobe Encore DVD menu backgrounds for a 1440 x 1080 project, they must be 1920 x 1080 (.psd format for Encore).
    Jeff Pulera
    Safe Harbor Computers
  • Frank Butler
    October 24, 2008 at 9:27 pm
    Many thanks for the information. Much appreciated.
    Best Regards
    Frank
