Activity Forums VEGAS Pro still image from a project video clip
  • still image from a project video clip
    Posted by Bruce Wertovitch on June 26, 2007 at 1:31 pm
    I’m trying to get a useable still image from a project video clip in Vegas Movie Studio 6. I’ve done the two options above the preview window: saving to clipboard and saving as file. I’ve opened them in my photo program and have created the still photo. However, when I put that still back into the project and create a DVD, the still image is of such poor quality that it cannot be used. It’s so pixilated and blurry….just terrible. There must be a way to do this. Any help would be GREATLY appreciated.
    Bruce
    Gary Kleiner replied 19 years, 2 months ago 3 Members · 5 Replies
  • Gary Kleiner
    June 26, 2007 at 1:52 pm
    Before you save, set your preview resolution to Best>Full. Also temprarily set your project properties to non-interlaced (progressive).
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Bruce Wertovitch
    June 26, 2007 at 2:59 pm
    Thank you. I went to File–> Properties–> Project Properties. I have a box labeled “Deinterlace Method”. It’s drop down options are “Blend Fields” or “Interpolate Fields”. It’s set on “Blend Fields”. I don’t see anything about non-interlaced of progressive. You thoughts?
    Bruce
  • Terry Esslinger
    June 26, 2007 at 4:36 pm
    Look under File>Properties>video tab>Field order There should be 3 choices – you want none(progressive scan)
  • Bruce Wertovitch
    June 26, 2007 at 4:48 pm
    Got it. Thanks!! The only time I use this setting is just to capture the image, correct? At all other times, use the default setting which is “lower field first”?
    Bruce
  • Gary Kleiner
    June 26, 2007 at 5:56 pm
    For DV, yes.
    Gary Kleiner
