Activity Forums VEGAS Pro Still haven’t found a great solution or an exact fix….please help
  • Still haven’t found a great solution or an exact fix….please help
    Posted by Craig Scime on April 4, 2007 at 7:29 am
    I have read the posts on bringing in DVD’s to Vegas, using a DVD player, firewire and a computer. However some DVD’s are very Dark; and I believe this is so because of the differences in set up or something; the question is how to I correct that so it doesn’t look so milky or grainy? Is there an easy setting or corrector to fix the darkness or wrong setup, please be specific, if possible
    Also if there is a better way to get short clips from real dvd’s into vegas, or if you know of a good DVD capturing software that goes directly from my DVD drive, please let me know
    Thanks in advance
    Richard K replied 19 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • Gary Kleiner
    April 4, 2007 at 1:57 pm
    First, you should use File > Import> DVD Camcoder Disc.
    Probably, the best tool to do what you want is the Color Curves FX.
    Also, how are you judging if the video is dark? Your monitor may not be set up correctly. How does it look on the waveform monitor?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Craig Scime
    April 4, 2007 at 4:23 pm
    thanks gary, here’s a bit more. i am using the sony pro field montior that was calibrated by one of my engineers and everything usually looks beautiful; here’s the trick. When I load a dvd in my external player it plays great on my monitor, however the capture window is like half the brightness; to make things worse it only happens on some DVD’s. I can load other DVD’s the same way great, the monitor and capture window are almost identical. This is a big problem since I edit demo reels for actors and they all want there “10 seconds” of fame loaded in. One actor said he used to go to edit with some guy using an avid (big deal) and it always looked great. the footage I loaded yestday for a client, half is dark the other half is great.
    Thanks again
  • Gary Kleiner
    April 4, 2007 at 4:59 pm
    Sounds like your source may have copy protection on it.
    Gary Kleiner
  • Dave Petteruto
    April 4, 2007 at 6:16 pm
    Gary, I think you hit the nail on the head!!!
  • Craig Scime
    April 4, 2007 at 8:23 pm
    that’s great guys… but how can I fix it and prevent in the future. That’s really why I am at this forum.
  • Charles Avanti
    April 4, 2007 at 9:17 pm
    I don’t think an actors demo reel would have copy protection. How exactly are you getting the DVD video into Vegas?
    Charlie
  • Craig Scime
    April 4, 2007 at 9:25 pm
    if you reed my first 2 posts actors come to me to edit their demo, from movies they are in. thanks
  • Richard K
    April 6, 2007 at 2:29 am
    You could, if you were of a mind and willing to risk the legal consequences, use a program like DVD Shrink or DVD Decrypter to remove the copy protection, then bring the files into Vegas.
