Activity Forums Apple Final Cut Pro Legacy Still Have to Render Clips After Automatically Changing Sequence Settings to Match Clip Settings
  • Still Have to Render Clips After Automatically Changing Sequence Settings to Match Clip Settings
    Posted by Matthew Price on January 10, 2013 at 5:52 pm
    I’ve found a lot of messages similar to my issue, but not exactly the same. I apologize if there’s a solution I haven’t seen.
    I have a long .mov that I want to edit into smaller pieces. So, I created a new Final Cut Pro File (I have FCP 6.0.6). I marked my in and out points, and inserted the clip into the sequence.
    Naturally, I got the message saying the clip does not match the sequence settings. “Change sequence settings to match the clip settings?” I click yes.
    But it still requires me to render the clip! I cannot figure out why.
    Here are the clip settings:
    Matthew Price replied 13 years, 7 months ago 2 Members · 4 Replies
  • Shane Ross
    January 10, 2013 at 6:17 pm
    FCP doesn’t work with H.263 files natively. You need to convert the footage to ProRes first, THEN import and start editing.
    If you want to edit native, you need to use Adobe Premiere Pro CS6
    Shane
    Little Frog Post
  • Matthew Price
    January 10, 2013 at 6:46 pm
    How do I convert it to ProRes?
  • Shane Ross
    January 10, 2013 at 6:51 pm
    With Compressor…there are built in presets for ProRes. Drag in the file…then find the ProRes 422, or ProRes LT preset in the APPLE CODECS area…drag and drop, then hit SUBMIT.
    Shane
    Little Frog Post
  • Matthew Price
    January 10, 2013 at 7:26 pm
    Thanks for the help!
