Activity › Forums › Adobe Premiere Pro › Still have problem updating PPro 1.5 -> 1.5.1
Nomad1999 replied 21 years, 3 months ago 5 Members · 18 Replies
Steven L. gotz
May 29, 2005 at 1:40 pmThere must be differences between the US version and whatever version you guys have. I don’t have those files.
And by the way, I said to get rid of all of the Premiere Pro 1.5 folders. You got rid of one. How about the directory here:
“C:/Documents and Settings/Steven Gotz/Application Data/Adobe/Premiere Pro/1.5” (using your name of course)
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Steven L. gotz
May 29, 2005 at 1:48 pmWAIT!!!!
Sorry. I found them. I did a search and missed them. But when I looked in the directory, there they were. Sorry about that. My error.
ASLFoundation is the only one marked as 1.5.1 – the others are 1.5.0
It is a bit strange. It says it was created on March 2, 2005 at 12:55:03 AM and yet it was modified February 9, 2005
The build number is S243 – 2/9/2005
Steven
Andre Gagnon
May 29, 2005 at 6:47 pm[Nomad1999] “Or maybe you can email them to me to see if that solve my problem.”
Check your e-mail.
Andre
Nomad1999
May 29, 2005 at 8:58 pmAndre, I got the files but still no luck with the update.
My original build is S149 dates 2004 where yours is S150.
I really do think that my build is too old somehow.
Are those files you gave me are the original files before the Update?
I have also noticed that they are the sames as AE6.5, which I have also installed yesterday based on the fact that you had found the sames files there too. Note that my AE ASL* files are the same build as yours, ie: S150 but still not working.
that is strange that there seem to have different build out there that are not “compatible” with a basic upgrade.
Andre
Andre Gagnon
May 30, 2005 at 12:40 am[Nomad1999] “Are those files you gave me are the original files before the Update?”
Following special work that I do, I have two versions of PPro on my PC:
1)- PPro 1.5.1
ASLFoundation .dll is Build # S243 and File Version 1,5,1,0 (This one I sent you.)
2)- PPRO 1.5.0
ASLFoundation.dll Is Build # S158 and File Version 1,5,0,0 (Could send it upon request)
Nomad1999
June 3, 2005 at 1:10 amCan you send me the 1.5.0 versions of those DLL’s?
I will try to see if this works, but I am affraid that my entire version is an older build and will not accept the update 1.5.1.
Andre -
Granny Sherman
June 4, 2005 at 8:13 pmHi,
I am having the same problem.
Have you solved your’s ?
If so, please help,
Thanks in advance,
GS
Nomad1999
June 5, 2005 at 4:13 amGranny,
Nop I still haven’t solved mine yet.
I am hoping to get the ASF*.dll from a more recent build. and hopefully it will help.
It seem that Adobe as distributed some older build of Premiere Pro 1.5 and we are the unlucky early one who got them.My build is S149, where it seem that the patch will work only on more recent one like S154 or so.
