Activity › Forums › Adobe After Effects › Still Glitches
  • Still Glitches
    Posted by Thejman on November 4, 2006 at 4:52 am
    Hey, I’m a little new to using After Effects 7.0, but for some reason when I render small clips in NTSC there always seems to be little glitches aroung the Fx’s. Does anyone know how I can fix this? The glitches look like little checkered markings that flash everywhere, all over the screen. Is there any way around this or to fix this…when rendering it in other modes the glitches still appear, except in the Cinepak codec, but the glitches are very obvious, and I would like to eliminate them if possible. Thanks for the help!
    J
    Mylenium replied 19 years, 11 months ago 2 Members · 1 Reply
  • Mylenium
    November 4, 2006 at 9:22 am
    This sounds entirely like a compression problem and depending on what CoDec you use, this behavior is normal and inevitable. Only uncompressed CoDecs will not have any block artifacts but of course result in much larger file sizes. Anyway, AE isn’t that terribly well suited for creating compressed stuff, so if you really must (which I don’t believe, since you are rendering to NTSC res and probably use your stuff in a video) get external Tools like ProCoder or Sorenson Squeeze.
    Mylenium
    [Pour Myl
