Activity Forums Apple Final Cut Pro Legacy Still from FCP for Film Festival
  • Still from FCP for Film Festival
    Posted by Max Frank on July 13, 2006 at 8:57 pm
    The Film Festival want 5 stills from my film at the following specs:
    300 dpi
    18cm/7″ wide
    Color eps or jpeg
    Can anyone suggest the best workflow?
    I’m using the NTSC DV codec, so will I also have to interlace? How should I best do that?
    Thanks in advance,
    Wayne
    2DP G5, 3.5GB RAM, FCP HD
    Sherwood Ball replied 19 years, 10 months ago 3 Members · 3 Replies
  • Shane Ross
    July 13, 2006 at 9:00 pm
    Export from FCP as the default PNG file. It will be 720×480 at 72DPI. Take it into Photoshop and deinterlace it and increase the dimensions to what they require.
    Won’t look pretty though. DV stills tend to look mushy.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Max Frank
    July 14, 2006 at 9:59 am
    Shane,
    Thanks a lot for the info. Much appreciated.
    Wayne
  • Sherwood Ball
    July 14, 2006 at 9:35 pm
    Export the image as instructed in the earlier post, then import
    into Genuine Fractals for resolution bump up for print.
