Activity › Forums › RE:Vision Effects › still frames bug/problem
  • still frames bug/problem
    Posted by Georgi Georgiev on February 24, 2011 at 5:54 am
    Why are there few STILL frames sometimes when I use twixtor (in Premiere CS5)? The action is slow and smooth for a bit… but then for a second or a little less the picture freezes. When I scroll in premiere I can see 6 or 7 frames that are basically the same one after each other. And I have to delete them in order for the action to go smooth…
    Pierre Jasmin replied 15 years, 7 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    February 24, 2011 at 7:54 pm
    Hard to say without seeing your media, the project and the settings used.
    A usual suspect would be a tiny mismatch of FPS. Since Twixtor reads two existing frames to make a new frame, a slight mismatch of FPS can cause Twixtor to get twice the same frame – hence a freeze when slowed down.
    Pierre
