Activity Forums VEGAS Pro still confused on how to correctly make it widescreen.
  • still confused on how to correctly make it widescreen.
    Posted by Aldrian Alfonso on March 15, 2009 at 11:35 am
    ok i finally have a camcorder that does widescreen. so here is my questions. when i first launch sony vegas 8, i make it’s on ntsc widescreen so when i edit the preview window is at a widescreen format.
    when i render it, i use mpeg2 and dvd ntsc so i can put it on a dvd. but when i see the render preview window, the video is then in a box with black bars like what you would see when you watch a dvd on a tube tv. so am i formatting it right??? will it automatically stretch out when i put it on a widescreen tv???
    John Rofrano replied 17 years, 5 months ago 2 Members · 3 Replies
  • John Rofrano
    March 15, 2009 at 2:26 pm
    That’s your problem. Render you video with the DVD Architect NTSC Widescreen video stream template and then make an audio file using the same name with the Dolby Digital AC3 | Stereo DVD template and everything will be the correct aspect.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Aldrian Alfonso
    March 16, 2009 at 1:39 am
    huh? doesn’t that requiere me to re render the whole entire vid again?
    well i’m trying to just save it as a one whole video file so i can view it on my pc as well. or upload it on a website. so …
  • John Rofrano
    March 16, 2009 at 3:26 am
    Yes it does. You rendered it wrong. The only way to fix it is to render it correctly.
    ~jr
