Activity Forums Maxon Cinema 4D Sticker on glassa material
  • Sticker on glassa material
    Posted by Adam Tracksler on June 9, 2008 at 4:39 pm
    I’m mocking up a store display in C4d. I need to make the glass for the front of the store, the glass will have a sticker on it, I need the glass to be transparent with the sticker on it, how do I create such a material??
    Thanks in advance, ad
    P.S. Have a Nice Day!
    Zach Gunter replied 18 years, 3 months ago 2 Members · 2 Replies
  • Zach Gunter
    June 9, 2008 at 6:12 pm
    there is probably an easier way to do this, but here is how i would. Make your glass ( a plane or thin cube) and for your material set your tranparency down to like 10%. For you sticker, make a plane the demensions you want you sticker to be,(make sure the image your wanting has white around the image. Make a new material and for color click the texture arrow and select your stick image. also in alpha do the same. apply that material to the plane. Then all you have to do is position your sticker where you want it on your glass. You can also rescale the plane.
  • Zach Gunter
    June 9, 2008 at 6:13 pm
    sorry, on the texture part of both the color and alpha, it’s not the arrow it’s the (…) and then select your image.
