Activity › Forums › AJA Video Systems › Stereography Monitoring using Kona 3?
Posted by Tim Maloney on May 19, 2010 at 10:38 pmHi All,
Got a Kona 3 and a TV Logic with the two input spigots for 444 monitoring ( which I’ve never used !!)
Is there a device that would sit between the Kona and the TV Logic that would enable the display of stereo3D images??
I’ve heard about such a device but cant find it!!!!
Likely workflow is using the upcoming Panasonic S3D cameras
Best
Tim Maloney
Axis FilmsTim Maloney
Managing Director
Axis Films Melbourne Australia
tim@axisfilms.com.auMichael replied 16 years, 4 months ago 6 Members · 9 Replies -
Bob Zelin
May 20, 2010 at 1:00 amKona 3 will support left channel on HD Out 1 and right channel on HD out 2. You don’t have to buy anything. Free upgrade. Will the TV Logic do it – probably not.
Bob Zelin
Tim Maloney
May 20, 2010 at 1:39 amThanks Bob, noted about the monitor and great news about the upgrade.
Working bacwkards then what sits between the kona 3 and FCS3 to split things L R?
Tim MaloneyTim Maloney
Managing Director
tim@axisfilms.com.au -
Shane Ross
May 20, 2010 at 1:45 am[Tim Maloney] “Working bacwkards then what sits between the kona 3 and FCS3 to split things L R? “
Nothing. The Kona 3 will send L out one SDI port and right out another SDI port. What you need is a monitor that is 3D capable. One that will accept the L and the R and mix them properly. At NAB, they had the SDI outs going to Hi-5 adapters, converting that to HDMI, and then they connected that to an HDTV that is 3D capable. Two HDMI inputs.
THAT is what you need.
Shane
Read my blog, Little Frog in High Def -
Tim Maloney
May 20, 2010 at 8:58 pmThanks Shane and Bob,
As I said I get the Kona 3/ Monitor set up – thank you.
I’ll have from the Panasonic camera, two cards with the L R captured to each.
So I open log and transfer in FCP and I ……………. ?
Can you please fill in the workflow, Do I need to buy any thing other than the screen??
Best
Tim Maloney
Axis Films AustraliaTim Maloney
Managing Director
Jeremy Garchow
May 20, 2010 at 9:03 pm[Tim Maloney] “Can you please fill in the workflow, Do I need to buy any thing other than the screen?? “
This is impossible to predict as nothing is released yet, but maybe plinking around here will help you:
https://pro-av.panasonic.net/en/3d/
Shane Ross
May 20, 2010 at 10:32 pmLook up CINEFORM… that’s what you’ll need to conform to. THEIR workflow. It’s so new, I don’t know it.
Shane
Tim Maloney
May 21, 2010 at 3:55 amThanks Bob Shane Jeremy,
Off to read about Cineforms neo3d for mac.
Cheers
Tim
Tim Maloney
Managing Director
Gary Adcock
May 21, 2010 at 1:50 pm[Tim Maloney] “I’ll have from the Panasonic camera, two cards with the L R captured to each.
Can you please fill in the workflow, Do I need to buy any thing other than the screen?? “Tim
there are a whole lotta steps before you get to FCP.
NO you do not use L&T in the Cineform workflow- you will need to handle the content as R & L files- convert them to the Cineform codec and then mux the stereo files inside of Cineform before handing them off to FCP.
You will also need to align the R&L in a frame accurate fashion prior to muxing the images.
you may need to change one of the camera orientations when using an over / under rig.please remember that left eye is dominant in 3D…
Not to mention you really do need a stereo capable display to view and edit the content correctly.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://blogs.creativecow.net/24640
Michael
May 21, 2010 at 8:56 pmYou do not even need a Kona 3. All you need is a card with an HDMI or HDSDI output. Cineform muxes the eyes into a side-by-side image. As far as the card is concerned, it’s just another HD signal.
It’s the TV that “demuxes” the side by side image and produces a 3d image.
You do need the Kona 3 with some projection systems that require 2 separate streams.
And a warning: Cineform is $3k. There’s also “Stereo 3d Toolbox” that’s a plugin for FCP. It’s less expensive, but requires just about every shot to be rendered. And we all know how good FCP is about keeping track of renders.
Michael Heldman
Spot Welders
