Activity › Forums › Apple Final Cut Pro Legacy › steps to editing red raw files
Posted by Nancy Rosenblum on August 21, 2010 at 9:58 pmCan some one list for me in a step 1,2,3 fashion how to import and transcode RAW RED files for an off-line cut from the RED camera hard drive to another drive and into final cut for editing?
What is the difference between HQ, LT and Proxy? Would I use HQ?
thanks.
NancyGary Adcock replied 16 years, 1 month ago 4 Members · 3 Replies -
Michael Gissing
August 21, 2010 at 11:17 pmNancy, if you have read the workflow information available from the RED site and searched the forums here and at RED and still are confused about the workflow, then I highly recommend you seek a post production technical specialist to setup a fool proof workflow.
Having sorted a few RED jobs, I can assure you that it is not simple and there are so many specific aspects that need to be sorted, starting with what is to be delivered, the offline/ online work path and edit systems that will be used along the way, including, FCP/ AVID, AE etc. It is far from a simple 1,2,3 approach.
Petr Tomkevich
August 22, 2010 at 11:03 pmgo on there and download the final cut pro installer but make sure you have the right one. If you have a newer camera build, you may need to purchase FCS 3. The file that comes with it has a lot of good info on basic transcoding. Also, download REDCINE-X and RED ALERT and use reduser.net for questions about RED workflows.
-Petr
Gary Adcock
August 23, 2010 at 12:01 am>> and use reduser.net for questions about RED workflows. << The Red Forum here on the Cow has been offering a wider range of information since the cameras have been shipping. Really- Noah is one of the preeminent authors on Red cameras, Stuart, David and I have been here awhile, https://mobi.creativecow.net/forum/redcamera
gary adcock
Studio37Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, ILhttps://blogs.creativecow.net/24640
