Activity Forums Adobe After Effects “Steppy” Particular Trail
  • “Steppy” Particular Trail
    Posted by Pravin Chottera on August 7, 2014 at 4:57 pm
    I’m trying to make the “tail” of a comet that is orbiting very fast.
    The problem is that the tail is looking “steppy” because Particular seems to be interpolating linearly between the motion path segments.
    Here are some screen shots to illustrate the problem.
    Is there any way to eliminate the steppyness? I can make the whole movement slower so there are more points to interpolate between, pre comp it, and then speed it up, but I want to think there is a better solution.
    Pravin Chottera replied 12 years, 1 month ago 2 Members · 2 Replies
  • Michael Szalapski
    August 7, 2014 at 5:55 pm
    There is a setting in Particular to change this! Under Emitter>Position Subframe, change it to something other than linear.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Pravin Chottera
    August 7, 2014 at 8:57 pm
    I knew it was just one button I was missing!
    Many thanks!
