Activity › Forums › Adobe After Effects › Step and Repeat Comp…
  • Step and Repeat Comp…
    Posted by Brian Tuminaro on October 25, 2013 at 6:54 pm
    Hi All,
    I’m curious as to if there is a way to duplicate and space a comp through and effect or expression.
    Example: Let’s say I have a comp of a circle with a simple scale animation. I would want this comp duplicate 50 times and set in a grid fashion 10 across and 5 down. And if I edit the original animation all duplicates would update as well.
    Any help would be fantastic.
    Todd Kopriva replied 12 years, 11 months ago 3 Members · 4 Replies
  • Mathew Fuller
    October 25, 2013 at 7:24 pm
    You need to pick-whip the scale value on all of the duplicate layers to the scale value of a comp that you choose to be the parent of all layers, and then animate the scale of only that master layer.
    My Work:
    https://www.morecompletefx.com
  • Brian Tuminaro
    October 25, 2013 at 7:27 pm
    Ahhhhh….
    Thanks Mathew.
  • Todd Kopriva
    October 25, 2013 at 9:23 pm
    This is made much easier with the new “property link” feature in After Effects CC (12.1), due out next week:
    https://adobe.ly/AE_CC_12dot1_details
    After Effects team blog
  • Todd Kopriva
    October 31, 2013 at 8:55 pm
    Try the new Copy With Property Links command with the new update, available now.
    For complete details, see this page.
