Activity Forums Avid Media Composer Steam Size Error H.264 to XDCAM HD 50 on Clips 10min +
  • Steam Size Error H.264 to XDCAM HD 50 on Clips 10min +
    Posted by Ted Machilles on November 20, 2014 at 6:13 pm
    Hi there,
    This is a problem I’ve had on multiple computers and Avids, mainly working on NewsCutter 10, but I’ve seen it in a few Media Composers too.
    Error:
    Exception: STEAM_SIZE_EXCEEDED, className:ameBaseSteam
    The problem always occurs when AMA linked to one or more files of H.264 material usually from a Canon DSLR or GoPro. So I’m guessing the QT mov container has something to do with it. I’m typically transcode/consolidating the material to XDCAM HD 50Mbits. Doesn’t matter if material is native to the project or not, it almost always occurs if the clip is over 10 minutes long. I never have any problems with shorter material. I can successfully Import the material at the same settings but if AMA link files, then transcode it fails 95% of the time.
    This is really annoying me. Anyone else experience this and have a better work around then the Import function? Or know what I could be doing to avoid this error and still AMA link?
    Much appreciated.
    -Ted
    Ted Machilles replied 11 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
